TwinTurbo.NET: Nissan 300ZX forum - you only need to add oil if you're getting low numbers
Subject you only need to add oil if you're getting low numbers
Posted by Nismoz3255 (Albany) on June 24, 2008 at 9:07 PM
  This message has been viewed 143 times.
In Reply To Compression Testing -- How to add oil to cylinder??? posted by jzack on June 24, 2008 at 08:07 PM
Message the oil seals the rings to tell you if they're the problem for the low compression. If you're getting good consistent compression there is no need to add oil. If you need to though I've just poured a tiny bit from the cap of the oil bottle through the spark plug hole.
